Why after I add an edge causes the web problem like CORS, the error message is the following text :[Info] Websocket connecting to URL [ws://az-ems.pplc.co:8082] (main.js, line 30081)
[Warning] [blocked] The page at https://az-ems.pplc.co/index was not allowed to run insecure content from ws://az-ems.pplc.co:8082/. (main.js, line 114459)
Hi and welcome to the community,
CORS is a restriction to load data from another URL.
If you run a public facing OpenEMS Backend + UI setup, it is always recommended to use a proxy server in front, like NGINX, that serves as a proxy for the individual endpoints. See the architectural diagram:
https://openems.github.io/openems.io/openems/latest/introduction.html#_system_architecture
This is an example NGINX configuration:
server {
server_name openems.example.com;
listen 443 ssl default;
root /var/www;
# Proxy for OpenEMS Edge -> OpenEMS Backend
location ^~ /openems-backend {
limit_req zone=limitreqsbyaddr;
proxy_pass http://127.0.0.1:8091;
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header Connection "upgrade";
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
keepalive_timeout 120s;
proxy_connect_timeout 120s;
proxy_read_timeout 300s;
proxy_send_timeout 300s;
access_log /var/log/nginx/openems-edge.access.log;
error_log /var/log/nginx/openems-edge.error.log;
# Proxy for OpenEMS UI -> OpenEMS Backend
location /openems-ui {
proxy_pass http://127.0.0.1:8092;
proxy_ssl_server_name on;
keepalive_timeout 6000s;
proxy_connect_timeout 6000s;
proxy_read_timeout 6000s;
proxy_send_timeout 6000s;
access_log /var/log/nginx/openems-ui.access.log;
error_log /var/log/nginx/openems-ui.error.log;
# Location for OpenEMS UI
location / {
alias /var/www/openems-ui;
index index.html;
try_files $uri$args /m/index.html;
Make sure to adjust your UI environment file accordingly to use the correct URL endpoint. Example:
import { Environment } from "src/environments";
import { theme } from "./theme";
export const environment: Environment = {
...theme, ...{
backend: 'OpenEMS Backend',
url: "wss://openems.example.com/openems-ui",
production: true,
debugMode: false
And in your OpenEMS Edge instance, configure the Controller Api Backend URI
configuration parameter to wss://openems.example.com/openems-edge
Thank you, Stefan, I follow your advice by changing the [UI environment file] and solved my problem.
