Hallo !
hab mal den Versuch gewagt, das in mein UI einzubauen, leider erhalte ich immer folgendes:
PS E:\git\openems\ui> ng build -c “openems,openems-backend-prod,prod”
Your global Angular CLI version (15.1.4) is greater than your local version (15.0.4). The local Angular CLI version is used.
To disable this warning use “ng config -g cli.warnings.versionMismatch false”.
⠋ Generating browser application bundles (phase: setup)… TypeScript compiler options “target” and “useDefineForClassFields” are set to “ES2022” and “false” respectively by the Angular CLI. To control ECMA version and features use the Browerslist configuration. For more information, see Angular
Browser application bundle generation complete.
Error: src/app/edge/live/receipt/modal/modal.component.html:1:1 - error NG8001: ‘ion-header’ is not a known element:
- If ‘ion-header’ is an Angular component, then verify that it is part of this module.
- If ‘ion-header’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
1
src/app/edge/live/receipt/modal/modal.component.ts:15:18
15 templateUrl: "./modal.component.html",
Error occurs in the template of component ReceiptModalComponent.
Error: src/app/edge/live/receipt/modal/modal.component.html:2:5 - error NG8001: 'ion-toolbar' is not a known element:
1. If 'ion-toolbar' is an Angular component, then verify that it is part of this module.
2. If 'ion-toolbar' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
2 <ion-toolbar class="ion-justify-content-center" color="primary">
Error: src/app/edge/live/receipt/modal/modal.component.html:3:9 - error NG8001: 'ion-title' is not a known element:
1. If 'ion-title' is an Angular component, then verify that it is part of this module.
2. If 'ion-title' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
3 <ion-title translate>Edge.Index.Widgets.Receipt.receipt</ion-title>
Error: src/app/edge/live/receipt/modal/modal.component.html:4:9 - error NG8001: 'ion-buttons' is not a known element:
1. If 'ion-buttons' is an Angular component, then verify that it is part of this module.
2. If 'ion-buttons' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
4 <ion-buttons slot="end">
Error: src/app/edge/live/receipt/modal/modal.component.html:5:13 - error NG8001: 'ion-button' is not a known element:
1. If 'ion-button' is an Angular component, then verify that it is part of this module.
2. If 'ion-button' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
5 <ion-button (click)="modalCtrl.dismiss()">
Error: src/app/edge/live/receipt/modal/modal.component.html:6:17 - error NG8001: 'ion-icon' is not a known element:
1. If 'ion-icon' is an Angular component, then verify that it is part of this module.
2. If 'ion-icon' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
6 <ion-icon name="close-outline"></ion-icon>
Error: src/app/edge/live/receipt/modal/modal.component.html:12:1 - error NG8001: 'ion-content' is not a known element:
1. If 'ion-content' is an Angular component, then verify that it is part of this module.
2. If 'ion-content' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
12 <ion-content>
15 templateUrl: “./modal.component.html”,
Error: src/app/edge/live/receipt/modal/modal.component.html:13:5 - error NG8001: ‘ion-card-content’ is not a known element:
- If ‘ion-card-content’ is an Angular component, then verify that it is part of this module.
- If ‘ion-card-content’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
13
Error: src/app/edge/live/receipt/modal/modal.component.html:26:85 - error NG8004: No pipe found with name ‘unitvalue’.
26 {{ pickedComponentsEnergy == null? “-”:pickedComponentsEnergy | unitvalue:‘kWh’ }}
Error: src/app/edge/live/receipt/modal/modal.component.html:57:5 - error NG8001: ‘ion-card-content’ is not a known element:
57
Error: src/app/edge/live/receipt/modal/modal.component.html:58:9 - error NG8001: ‘ion-row’ is not a known element:
- If ‘ion-row’ is an Angular component, then verify that it is part of this module.
- If ‘ion-row’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
58
Error: src/app/edge/live/receipt/modal/modal.component.html:59:13 - error NG8001: ‘ion-note’ is not a known element:
- If ‘ion-note’ is an Angular component, then verify that it is part of this module.
- If ‘ion-note’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
59
Error: src/app/edge/live/receipt/modal/modal.component.html:68:9 - error NG8001: ‘ion-grid’ is not a known element:
- If ‘ion-grid’ is an Angular component, then verify that it is part of this module.
- If ‘ion-grid’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
68
Error: src/app/edge/live/receipt/modal/modal.component.html:69:13 - error NG8001: ‘ion-row’ is not a known element:
69
Error: src/app/edge/live/receipt/modal/modal.component.html:70:17 - error NG8001: ‘ion-buttons’ is not a known element:
- If ‘ion-buttons’ is an Angular component, then verify that it is part of this module.
- If ‘ion-buttons’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
70
Error: src/app/edge/live/receipt/modal/modal.component.html:71:21 - error NG8001: ‘pickdate’ is not a known element:
- If ‘pickdate’ is an Angular component, then verify that it is part of this module.
- To allow any element add ‘NO_ERRORS_SCHEMA’ to the ‘@NgModule.schemas’ of this component.
71
Error: src/app/edge/live/receipt/modal/modal.component.html:82:9 - error NG8001: ‘ion-grid’ is not a known element:
82
Error: src/app/edge/live/receipt/modal/modal.component.html:83:13 - error NG8001: ‘ion-row’ is not a known element:
83
Error: src/app/edge/live/receipt/modal/modal.component.html:84:17 - error NG8001: ‘ion-col’ is not a known element:
- If ‘ion-col’ is an Angular component, then verify that it is part of this module.
- If ‘ion-col’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
84
Error: src/app/edge/live/receipt/modal/modal.component.html:85:21 - error NG8001: ‘ion-item’ is not a known element:
- If ‘ion-item’ is an Angular component, then verify that it is part of this module.
- If ‘ion-item’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
85
Error: src/app/edge/live/receipt/modal/modal.component.html:86:25 - error NG8001: ‘ion-label’ is not a known element:
- If ‘ion-label’ is an Angular component, then verify that it is part of this module.
- If ‘ion-label’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
86
Error: src/app/edge/live/receipt/modal/modal.component.html:89:25 - error NG8001: ‘ion-datetime’ is not a known element:
- If ‘ion-datetime’ is an Angular component, then verify that it is part of this module.
- If ‘ion-datetime’ is a Web Component then add ‘CUSTOM_ELEMENTS_SCHEMA’ to the ‘@NgModule.schemas’ of this component to suppress this message.
89 <ion-datetime (ionChange)=“fromTimeChanged($event)”
90 [cancelText]=“translate.instant(‘General.cancel’)” [value]=“fromTime”
91 [doneText]="translate.instant('General.ok')" displayFormat="HH:mm" pickerFormat="HH:mm"
92 minuteValues=“0,5,10,15,20,25,30,35,40,45,50,55”>
Error: src/app/edge/live/receipt/modal/modal.component.html:90:29 - error NG8002: Can't bind to 'cancelText' since it isn't a known property of 'ion-datetime'.
1. If 'ion-datetime' is an Angular component and it has 'cancelText' input, then verify that it is part of this module.
2. If 'ion-datetime' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
3. To allow any property add 'NO_ERRORS_SCHEMA' to the '@NgModule.schemas' of this component.
90 [cancelText]="translate.instant('General.cancel')" [value]="fromTime"
Error: src/app/edge/live/receipt/modal/modal.component.html:90:80 - error NG8002: Can't bind to 'value' since it isn't a known property of 'ion-datetime'.
1. If 'ion-datetime' is an Angular component and it has 'value' input, then verify that it is part of this module.
Error: src/app/edge/live/receipt/modal/modal.component.html:91:29 - error NG8002: Can't bind to 'doneText' since it isn't a known property of 'ion-datetime'.
1. If 'ion-datetime' is an Angular component and it has 'doneText' input, then verify that it is part of this module.
Error: src/app/edge/live/receipt/modal/modal.component.html:96:17 - error NG8001: 'ion-col' is not a known element:
1. If 'ion-col' is an Angular component, then verify that it is part of this module.
2. If 'ion-col' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
96 <ion-col size-xl="3" size-md="6" size-sm="12">
Error: src/app/edge/live/receipt/modal/modal.component.html:97:21 - error NG8001: 'ion-item' is not a known element:
1. If 'ion-item' is an Angular component, then verify that it is part of this module.
2. If 'ion-item' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
97 <ion-item lines="none" class="ion-text-start">
Error: src/app/edge/live/receipt/modal/modal.component.html:98:25 - error NG8001: 'ion-label' is not a known element:
1. If 'ion-label' is an Angular component, then verify that it is part of this module.
2. If 'ion-label' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
98 <ion-label translate>
Error: src/app/edge/live/receipt/modal/modal.component.html:101:25 - error NG8001: 'ion-datetime' is not a known element:
1. If 'ion-datetime' is an Angular component, then verify that it is part of this module.
101 <ion-datetime (ionChange)="toTimeChanged($event)"
102 [cancelText]="translate.instant('General.cancel')" [value]="toTime"
103 [doneText]="translate.instant('General.ok')" displayFormat="HH:mm" pickerFormat="HH:mm"
104 minuteValues="0,5,10,15,20,25,30,35,40,45,50,55">
Error: src/app/edge/live/receipt/modal/modal.component.html:102:29 - error NG8002: Can't bind to 'cancelText' since it isn't a known property of 'ion-datetime'.
Error: src/app/edge/live/receipt/modal/modal.component.html:102:80 - error NG8002: Can't bind to 'value' since it isn't a known property of 'ion-datetime'.
Error: src/app/edge/live/receipt/modal/modal.component.html:103:29 - error NG8002: Can't bind to 'doneText' since it isn't a known property of 'ion-datetime'.
Error: src/app/edge/live/receipt/modal/modal.component.html:111:5 - error NG8001: 'ion-card-content' is not a known element:
1. If 'ion-card-content' is an Angular component, then verify that it is part of this module.
2. If 'ion-card-content' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
111 <ion-card-content class="underline">
Error: src/app/edge/live/receipt/modal/modal.component.html:112:9 - error NG8001: 'ion-grid' is not a known element:
1. If 'ion-grid' is an Angular component, then verify that it is part of this module.
2. If 'ion-grid' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
112 <ion-grid>
Error: src/app/edge/live/receipt/modal/modal.component.html:113:13 - error NG8001: 'ion-row' is not a known element:
1. If 'ion-row' is an Angular component, then verify that it is part of this module.
2. If 'ion-row' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
113 <ion-row class="ion-justify-content-center">
Error: src/app/edge/live/receipt/modal/modal.component.html:114:17 - error NG8001: 'ion-button' is not a known element:
114 <ion-button fill="outline" (click)="presentPopover()" translate>
Error: src/app/edge/live/receipt/modal/modal.component.html:120:5 - error NG8001: 'ion-card-content' is not a known element:
120 <ion-card-content>
Error: src/app/edge/live/receipt/modal/modal.component.html:121:9 - error NG8001: 'ion-grid' is not a known element:
121 <ion-grid>
Error: src/app/edge/live/receipt/modal/modal.component.html:122:13 - error NG8001: 'ion-row' is not a known element:
122 <ion-row class="ion-justify-content-center">
Error: src/app/edge/live/receipt/modal/modal.component.html:123:17 - error NG8001: 'ion-button' is not a known element:
123 <ion-button translate (click)="createReceipt()">
Error: src/app/edge/live/receipt/popover/popover.component.html:1:1 - error NG8001: 'ion-list' is not a known element:
1. If 'ion-list' is an Angular component, then verify that it is part of this module.
2. If 'ion-list' is a Web Component then add 'CUSTOM_ELEMENTS_SCHEMA' to the '@NgModule.schemas' of this component to suppress this message.
1 <ion-list>
src/app/edge/live/receipt/popover/popover.component.ts:11:18
11 templateUrl: './popover.component.html'
Error occurs in the template of component ReceiptPopoverComponent.
An was könnte das liegen ?
