Hello Everybody,
I have a problem with getting access to the apache felix web console. The default port: 8080 is already in use on my computer so I want so change the used port in openEMS.
But I don´t know where to change the port.
What I tried is the following:
I changed the port in the EdgeApp Source document (to 8888)
It seems to have worked. The console output I get is the following:
org.apache.felix.http.jetty [org.eclipse.jetty.server.AbstractConnector] INFO : Started ServerConnector@5d47f08d{HTTP/1.1, (http/1.1)}{0.0.0.0:8888}
2021-11-10 15:11:45,715 [artLevel] INFO [org.apache.felix.http.jetty ] Started Jetty 9.4.43.v20210629 at port(s) HTTP:8888 on context path / [minThreads=8,maxThreads=200,acceptors=2,selectors=10]
2021-11-10 15:11:45,773 [artLevel] WARN [ntmanager.ComponentManagerImpl] bundle io.openems.edge.core:1.0.0.202111101345 (75)[io.openems.edge.core.componentmanager.ComponentManagerImpl(1)] : Could not get service from ref [io.openems.edge.common.component.ComponentManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi, org.osgi.service.cm.ConfigurationListener]
2021-11-10 15:11:45,774 [artLevel] ERROR [ROOT ] bundle org.apache.felix.scr:2.1.30 (162) Circular reference detected trying to get service [io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi]
stack of references: ServiceReference: [io.openems.edge.predictor.api.manager.PredictorManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi]
ServiceReference: [io.openems.edge.common.component.ComponentManager, io.openems.edge.common.component.OpenemsComponent, io.openems.edge.common.jsonapi.JsonApi, org.osgi.service.cm.ConfigurationListener]
But I still got an error when trying to open the web console in the browser: HTTP ERROR 404 Not Found
Do I have to change the port somewhere else or is it possible that I have a different porblem?
I am gratefull for any advise.
Best Regards
Tobi
elsewise you would get n timeout.
