Hi everybody,
I wanted to ask if anybody has ever dockerized the EdgeApp? If yes, can you share your Dockerfile and docker-compose files?
Cheers,
Karolina
Hi Karolina,
OpenEMS is used widely in Docker containers, e.g. our Gitpod Live-Demo is powered by Docker (see the Gitpod specific Docker configuration here: openems/.gitpod.Dockerfile at develop Ā· OpenEMS/openems Ā· GitHub). Unfortunately there is no āstandardā Docker container available yet.
You can build your own dockerized OpenEMS Edge using the following Linux commands:
- Create a working directory and change to it
mkdir openems-edge
cd openems-edge
- Create subdirectories for configuration files and storage data
mkdir -p config data`
- Create a
Dockerfile:
cat <<EOF > Dockerfile
FROM eclipse-temurin:11-jre-alpine
RUN mkdir /opt/openems-edge
COPY openems-edge.jar /opt/openems-edge
CMD ["java", "-jar", "-Dfelix.cm.dir=/etc/openems.d/", "-Dopenems.data.dir=/var/lib/openems/", "/opt/openems-edge/openems-edge.jar"]
EOF
- Provide a
openems-edge.jarfile in the current directory. For example this command downloads the latest artifact from the latest GitHub Release version:
curl -s https://api.github.com/repos/OpenEMS/openems/releases/latest | awk -F\" '/browser_download_url.*openems-edge\.jar/{print $(NF-1)}' | xargs wget -O openems-edge.jar
- Build the Docker Image in the current directory
docker build -t openems-edge .
- Run the Docker Container
docker run --volume=$(pwd)/config:/etc/openems.d --volume=$(pwd)/data:/var/lib/openems --publish=8080:8080 openems-edge
I am by far no expert in Docker, so if there is anything incomplete or wrong with this guide, please provide feedback. Also I believe it might be a good idea to build official docker images in future via GitHub Actions, just like we create Release artifacts.
Hey there,
iām also no Docker Expert, but i ran the Edge-Controller and the UI without Problemes in my own Docker-Environment. Iāve used Docker-Compose so this may help:
version: ā3ā
services:
openems-edge:
image: openjdk:11
container_name: openems-edge
restart: unless-stopped
volumes:
- ā/opt/docker/appdata/openems:/dataā
working_dir: /data
ports:
- 8080:8080
- 8074:8074
- 8075:8075
command: java -Dfelix.cm.dir=/data/edge_config -jar openems-edge.jar
openems-ui:
image: nginx:latest
container_name: openems-ui
volumes:
- ā/opt/docker/appdata/openems/ui/nginx/default.conf:/etc/nginx/conf.d/default.confā
- ā/opt/docker/appdata/openems/ui/www:/usr/share/openems/wwwā
ports:
- 80:80
Greetings
Richard
in my environment iām using traefik with openems and influxdb. Maybe this code is helpful for someone.
version: ā3ā
services:
openems_edge:
image: openjdk:11
restart: always
networks:
- proxy
ports:
- ā8080:8080ā
- ā8084:8084ā
- ā8085:8085ā
volumes:- /storage/Config/Openems:/data working_dir: /data command: java -Dfelix.cm.dir=/data/openems.d -jar openems.jarinfluxdb2:
image: influxdb:latest
container_name: openems-influxdb
restart: always
networks:
- proxy
ports:
- ā8086:8086ā
volumes:
- /storage/InfluxData:/var/lib/influxdb2openems_nginx:
image: nginx:latest
volumes:
- /storage/Config/Openems/ui:/usr/share/nginx/html
- /storage/Config/Openems/nginx:/etc/nginx
networks:
- proxy
restart: always
labels:
- ātraefik.enable=trueā
- ātraefik.docker.network=proxyā
# Https (Errorpages have to be handle in /nginx/conf.d/default.conf ā āerror_page 404 /index.html;ā)
- ātraefik.http.routers.openems-secure.entrypoints=websecureā
- ātraefik.http.routers.openems-secure.rule=Host(openems.example.de)ā
- ātraefik.http.services.openems-service.loadbalancer.server.port=80ā
# Websocket
- ātraefik.http.routers.openems-ws.entrypoints=websecureā
- ātraefik.http.routers.openems-ws.rule=Host(openems.example.de) && Path(/websocket)ā
- ātraefik.http.routers.openems-ws.service=ws-openems-service@fileānetworks:
proxy:
external: true
Best regards
Christian
Hi Stefan et al.,
according to your instructions I installed openems-edge in a docker container which worked pretty good. Thank you for that.
Unfortunately I receive a bunch of Exceptions from java side I donāt understand (itās to much). Maybe you, or someone else can point me to the direction what to do. Seems that Iām missing some dependencies that I do not see at first glance but it might have something to do with apache felix framework since it occurs many times?!? The original log is even longer but since restriction to 12000 characters I copied only the first lines.
Best regards and thank you in advance
Christian
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling Java Util Logging API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling SLF4J API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling Apache Commons Logging API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling JULI Logger API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling Avalon Logger API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling JBoss Logging API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling Log4J v1 API support.
org.ops4j.pax.logging.pax-logging-api [org.ops4j.pax.logging.internal.Activator] INFO : Enabling Log4J v2 API support.
org.ops4j.pax.logging.pax-logging-api [log4j2] INFO : Initializing Log4j2 using default configuration
org.ops4j.pax.logging.pax-logging-api [log4j2] INFO : Scanning for classes in '/org/ops4j/pax/logging/log4j2/internal/bridges/' matching criteria annotated with @Plugin
org.ops4j.pax.logging.pax-logging-api [log4j2] INFO : Scanning for classes in '/org/apache/logging/log4j/layout/template/json/' matching criteria annotated with @Plugin
org.ops4j.pax.logging.pax-logging-api [log4j2] INFO : Scanning for classes in '/org/apache/logging/log4j/layout/template/json/resolver/' matching criteria annotated with @Plugin
org.ops4j.pax.logging.pax-logging-api [log4j2] INFO : Scanning for classes in '/org/apache/logging/log4j/layout/template/json/util/' matching criteria annotated with @Plugin
org.ops4j.pax.logging.pax-logging-api [log4j2] INFO : Log4J2 configured using default configuration.
org.ops4j.pax.logging.pax-logging-log4j2 [org.ops4j.pax.logging.spi.support.EventAdminConfigurationNotifier] INFO : Sending Event Admin notification (configuration successful) to org/ops4j/pax/logging/Configuration
ERROR: Bundle io.openems.edge.application [10] Error starting jar/io.openems.edge.application.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.application [10](R 10.0): missing requirement [io.openems.edge.application [10](R 10.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.types)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.application [10](R 10.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.types)(version>=1.0.0)(!(version>=2.0.0)))])
at org.apache.felix.framework.Felix.resolveBundleRevision(Felix.java:4398)
at org.apache.felix.framework.Felix.startBundle(Felix.java:2308)
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1566)
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:297)
at java.base/java.lang.Thread.run(Unknown Source)
ERROR: Bundle io.openems.common [9] Error starting jar/io.openems.common.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17)) Unresolved requirements: [[io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))])
ERROR: Bundle io.openems.edge.battery.api [11] Error starting jar/io.openems.edge.battery.api.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.api [11](R 11.0): missing requirement [io.openems.edge.battery.api [11](R 11.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.api [11](R 11.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
ERROR: Bundle io.openems.edge.battery.bmw [12] Error starting jar/io.openems.edge.battery.bmw.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.bmw [12](R 12.0): missing requirement [io.openems.edge.battery.bmw [12](R 12.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.bmw [12](R 12.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
ERROR: Bundle io.openems.edge.battery.bydcommercial [13] Error starting jar/io.openems.edge.battery.bydcommercial.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.bydcommercial [13](R 13.0): missing requirement [io.openems.edge.battery.bydcommercial [13](R 13.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.bydcommercial [13](R 13.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
ERROR: Bundle io.openems.edge.battery.fenecon.commercial [14] Error starting jar/io.openems.edge.battery.fenecon.commercial.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.fenecon.commercial [14](R 14.0): missing requirement [io.openems.edge.battery.fenecon.commercial [14](R 14.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.fenecon.commercial [14](R 14.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
ERROR: Bundle io.openems.edge.battery.fenecon.home [15] Error starting jar/io.openems.edge.battery.fenecon.home.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.fenecon.home [15](R 15.0): missing requirement [io.openems.edge.battery.fenecon.home [15](R 15.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.fenecon.home [15](R 15.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.soltaro [16](R 16.0): missing requirement [io.openems.edge.battery.soltaro [16](R 16.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.soltaro [16](R 16.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))]
ERROR: Bundle io.openems.edge.battery.soltaro [16] Error starting jar/io.openems.edge.battery.soltaro.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.battery.soltaro [16](R 16.0): missing requirement [io.openems.edge.battery.soltaro [16](R 16.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.battery.soltaro [16](R 16.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
org.osgi.framework.BundleException: Unable to resolve io.openems.edge.batteryinverter.api [17](R 17.0): missing requirement [io.openems.edge.batteryinverter.api [17](R 17.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.batteryinverter.api [17](R 17.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))]
at org.apache.felix.framework.Felix.resolveBundleRevision(Felix.java:4398)ERROR: Bundle io.openems.edge.batteryinverter.api [17] Error starting jar/io.openems.edge.batteryinverter.api.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.batteryinverter.api [17](R 17.0): missing requirement [io.openems.edge.batteryinverter.api [17](R 17.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.batteryinverter.api [17](R 17.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
ERROR: Bundle io.openems.edge.batteryinverter.kaco.blueplanetgridsave [18] Error starting jar/io.openems.edge.batteryinverter.kaco.blueplanetgridsave.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.batteryinverter.kaco.blueplanetgridsave [18](R 18.0): missing requirement [io.openems.edge.batteryinverter.kaco.blueplanetgridsave [18](R 18.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.batteryinverter.kaco.blueplanetgridsave [18](R 18.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
org.osgi.framework.BundleException: Unable to resolve io.openems.edge.batteryinverter.refu88k [19](R 19.0): missing requirement [io.openems.edge.batteryinverter.refu88k [19](R 19.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.batteryinverter.refu88k [19](R 19.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))]
ERROR: Bundle io.openems.edge.batteryinverter.refu88k [19] Error starting jar/io.openems.edge.batteryinverter.refu88k.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.batteryinverter.refu88k [19](R 19.0): missing requirement [io.openems.edge.batteryinverter.refu88k [19](R 19.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.batteryinverter.refu88k [19](R 19.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
ERROR: Bundle io.openems.edge.batteryinverter.sinexcel [20] Error starting jar/io.openems.edge.batteryinverter.sinexcel.jar (org.osgi.framework.BundleException: Unable to resolve io.openems.edge.batteryinverter.sinexcel [20](R 20.0): missing requirement [io.openems.edge.batteryinverter.sinexcel [20](R 20.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0))) [caused by: Unable to resolve io.openems.common [9](R 9.0): missing requirement [io.openems.common [9](R 9.0)] osgi.ee; (&(osgi.ee=JavaSE)(version=17))] Unresolved requirements: [[io.openems.edge.batteryinverter.sinexcel [20](R 20.0)] osgi.wiring.package; (&(osgi.wiring.package=io.openems.common.exceptions)(version>=1.0.0)(!(version>=2.0.0)))])
Hi chrizztus, welcome on board!
Are you able to run the āopenems.jarā file outside of the Docker container - e.g. using java -jar openems.jar?
You could try to use the āofficialā openems-edge.jar from the latest Release for a test: Releases Ā· OpenEMS/openems Ā· GitHub
How are you building your jar file? From command line or from Eclipse IDE? (see Build OpenEMS Edge :: Open Energy Management System)
Hi and thanks for welcoming me
Honestly Iām not a huge fan of having java runtime on my system, so in order to keep it clean I wanted to test the containerized approach. Can you (or someone else) confirm that the Dockerfile from your instructions builds and starts correctly?
I didnāt yet compile the project with Eclipse. Instead I wanted to try the latest build from the github release page you mentioned. Without luck so far :-/
Try to update the Dockerfile from @stefan.feilmeier. Since we upgraded Java to version 17 during the last months, try to adjust the java version.
Then you do
$ docker build -t openems .
to build the image and do
$ docker run --detach -p 8080:8080 openems
Now you should be able to open http://localhost:8080/system/console/configMgr and get the Apache Felix Web Console.
Let us know it that works for you!
Best,
Lorant
I am trying to dockerize the Edge App as well.
Without dockering i used to run the JAR file in Windows Terminal. And every time i restarted the EMS, it automatically read the config from c:/openems/config (as programmed to do here) :
Additionally i have also created External LOG files to store the warning and error. See my post here: OpenEMS export fehler + Speichern von Logs als externe Dateien
So in order to make sure that my dockerized Edge App could also read and edit the same config file and log files, i created volumes in the docker file:
VOLUME "C:\BIFLOW_LOGS\DEBUG" "C:\BIFLOW_LOGS\ERRORS" "C:\BIFLOW_LOGS\WARNINGS" "C:\openems\config"
I can see in the Docker desktop that the Edge App container is running at port 8080 and the log files are being updated. But for some reason the config data in āc:\openems\confgā is not being read and the EMS basically runs as a completely new start.
I am not able to figure out where i am making a mistake.
If i stop my container and let the jar file run back again in windows terminal the config is read, but not through the container.
Would really appreciate some help here.
Edit 1:
The command i am using to run the jar is as follows
CMD [ "java", "-jar", "-Dfelix.cm.dir=c:/openems/config/" , "-Dopenems.data.dir=c:/openems/data", "/openems-edge.jar" ]
Regards
Laksh
you can change the command to execute the jar file to point to the right location.
For example you can change the CMD line to the following and mount the config directories according it:
CMD [ "java", "-jar", "-Dfelix.cm.dir=/etc/openems/config/" , "-Dopenems.data.dir=/etc/openems/data", "/openems-edge.jar" ]
Hope it is helpful to you.
Best
I understood what i was doing wrong here. I was correct in providing the volumes details as well as the CMD, but the problem was that the volume was created with a random name in etc/data/⦠Thus while executing the config in my C drive was not correctly mounted. I later learnt about āNamed volumesā in docker container. This solved my problem. following is my new compose file:
version: '3.4'
services:
biflowemsmain:
volumes:
# config file
- "c:/openems/config:/etc/openems/config/:rw"
# data file
- "c:/openems/data:/etc/openems/data:rw"
image: biflowemsmain
restart: always
build:
context: .
dockerfile: ./Dockerfile
ports:
- 8080:8080
then my execution command is:
so here the mounted C drive config is taken into account and updated accordingly.
Regards
Laksh
EDIT: Please disregard. It appears like the issue is with my device code as it actually does appear to execute reads for other devices.
I am running the Edge in a Docker container with the following Dockerfile:
FROM eclipse-temurin:21-jre
ENV APP_HOME=/opt/ems-edge \
EMS_CONFIG_DIR=/etc/ems.d \
EMS_DATA_DIR=/var/lib/ems
# Optional but recommended: bash is missing on slim images
RUN set -eux; \
apt-get update; \
apt-get install -y --no-install-recommends bash; \
rm -rf /var/lib/apt/lists/*
# Create system user/group (Debian/Ubuntu syntax) and required dirs
RUN set -eux; \
# ensure group exists (nogroup usually exists already)
getent group nogroup >/dev/null || groupadd -r nogroup; \
# create system user if missing
if ! id -u openems >/dev/null 2>&1; then \
useradd -r -u 10001 -g nogroup -s /usr/sbin/nologin -M -d /nonexistent openems || \
useradd -r -u 10001 -g nogroup -s /sbin/nologin -M -d /nonexistent openems; \
fi; \
mkdir -p "$APP_HOME" "$EMS_CONFIG_DIR" "$EMS_DATA_DIR"; \
chown -R openems:nogroup "$APP_HOME" "$EMS_CONFIG_DIR" "$EMS_DATA_DIR"
# Copy app as non-root owner
COPY --chown=openems:nogroup openems-edge.jar $APP_HOME/openems-edge.jar
USER openems
WORKDIR $APP_HOME
# Shell-form so $EMS_* expand at runtime
CMD java -jar \
-Dfelix.cm.dir="$EMS_CONFIG_DIR/" \
-Dopenems.data.dir="$EMS_DATA_DIR/" \
"$APP_HOME/openems-edge.jar"
I am running in host networking mode. It seems like the EMS is not even trying to connect via Modbus TCP to my devices. I am able to connect to the devices from the container host using mbpoll and also from inside the container using curl/telnet.
But OpenEMS doesnāt even appear to try to connect when I track connections via tcpdump.
Does anyone have any suggestions as to what is going on?
