Simulation OpenEMS with my own Data (CSV File)
I’m interested in integrating my own data into OpenEMS using CSV files. Could you please guide me through the process? I would like to simulate the data and view the results.
Additionally, I’m curious about where I can find the CSV files with parameters for the example PV system in the software. Could you provide some guidance on this as well?
Thank you for your help.
Best regards,
What you could do is to use the component “Datasource CSV Direct” and paste your CSV file into the confguration. Then you can configure for example a “Simulated Production Meter Acting” and give it the datasource, and it will run through the datasouce, switching to the next value every core cycle, or after a time delta you can configure in the datasource.
The predefined CSV files you’ll find in the directory of the datasouce CSV predefined:
Of course you could also put your CSV file there and add it to the Source enum.
Best regards,
Hi dear :wave:,
you can read this post for more information about the ‘CSV-Source’ and CSV limitation for users who used own CSV files. it can be helpful :grinning:
Best regards,
Majid
thank you for your answer. But what would it ultimately look like in defiles or in the program? Do you have an example of this?
Best regards,
To speed up my simulation, I’m considering reducing the Core Cycle time to 1 ms. This would allow me to get my simulation results within a few minutes (I have 3 years data every 15 minutes, by reducing the Core cycle to 1 ms, it’s 900’000 times faster).
However, since my power measurements (Cycle core) are in Watts every 1 ms (but every 15 minutes according to my files), I’m wondering if the stored energy is representative of reality. Does it consider the 1 ms step for calculating stored energy, or is this irrelevant?
Changing the core cycle to speed up simulation in OpenEMS is not considered best practice. This is because the algorithm’s execution and the collection and updating of channels are performed every cycle, with a default interval of 1 second. changing this interval can lead to unwanted results.
For instance, consider the Battery Energy Storage System (BESS), which can be simulated using the SimulatorEssSymmetricReacting component. The BESS updates its channels each cycle, including the State of Charge (SoC) channel. The SoC is calculated based on actual energy, where energy is determined as:
Energy=Active Power×Duration.----> Soc= Energy×capacity
If you are working with a data source that has a different resolution, such as 15-minute intervals for consumption and production or grid data, this mismatch can cause issues. For example, if the core cycle is changed to 1 millisecond, the energy calculation would occur every 1 ms instead of every 15 minutes as the controller that control the BESS charge and discharge perform it logic every cycle !!. This leads to incorrect behavior, especially when the duration is derived from the OpenEMS clock, which reflects the real system clock.
Instead of modifying the core cycle, you should use the simulator app components provided by OpenEMS. These components are designed to handle large volumes of data efficiently and allow for seamless simulation. They also enable you to define a core cycle that matches your dataset’s resolution without introducing inconsistencies. For more information, refer to the OpenEMS documentation under the “Devices and Services” section, which explains how to simulate large-scale datasets effectively.
