Dear community,
I am sharing some improvements to the time-of-use-tariff optimization with you. The new implementation is now able to schedule charging of an electric vehicle during cheapest hours.
I am merging the code to next release, so testing is easy. See changes here:
The implemented use-case is as follows:
- Plug the car to the charging station
- Charging will be scheduled so that the car charges the configured
energySessionLimit(or 30 kWh if none is configured) till next day 7 am - This use-case follows the idea, that sufficient energy should be charged for the next commute to office.
To test the implementation:
- Use latest
developbranch (or Release 2025.1.0) - Configure
_energycomponentversion = V2_ENERGY_SCHEDULABLE - Configure
ctrlEvcs0component tosmartMode = true - Restart OpenEMS
- Give the Optimizer some time to calculate a proper schedule. It should calculate a bad version immediately and it will improve on every full 15-minutes.
- The Schedule is printed in the console log and can be visualized in the EVCS Modal in UI:
The PR lists some known bugs and TODOs:
- KEBA SessonEnergy:
- The way the KEBA charging station handles the SessionEnergy causes the above use-case to fail on the second day.
- Fix will come in a separate PR; for now simply increase the session-energy slightly in the Controller every day
- JSCalendar
- Currently “7am on every day” is hardcoded (see TARGET_HOUR)
- In future the
smartConfigconfiguration option will be used to hold a JsonArray compatible with JSCalender (RFC 8984). - This will allow configuring any kind of event, e.g. “charge 15 kWh till 7 am on weekdays”; “charge 40 kWh on sundays”. See JSCalendarTest for examples.
- InitialPopulation
- the InitialPopulation is a manually defined schedule that the Optimizer uses as the immediate “best result” and as start for its search through the solution space.
- Future improvements here will give faster better results. See InitialPopulation
I am looking forward to reading your feedback and test results. Thanks in advance!
Happy new year 2025!
